Activity Forums VEGAS Pro moving multiple files in the timeline.
  • moving multiple files in the timeline.
    Posted by Etwpro1 on July 30, 2007 at 11:34 pm
    im trying to figure out how to move multiple files in the timeline. i know you can hold shift and click on each one then move them. im trying to figure out how to highlight a section and move the whole section. i know i have done it before but i never knew how i did it. can anyone help? thanks.
    Edward Troxel replied 19 years, 1 month ago 7 Members · 8 Replies
  • 8 Replies
  • Terry Esslinger
    July 31, 2007 at 12:24 am
    You can use “select all” and then delete selections by “ctrl/click” leaving the ones you want to move as a block.
    If you have Excalibur it has a function for selecting and grouping.
    You can select the first one you wasnat to move and then “shif5t/click” the last one you want to move and you will have grouped those two plus any that are in between and you can move them as a block.
    Hope one of these helps.
  • Gary Kleiner
    July 31, 2007 at 4:02 am
    [etwpro1] “im trying to figure out how to highlight a section and move the whole section”
    Use the Selection Edit Tool (icon has an arrow) then drag across events you want to select. Then either drag them all together or Ctrl/X them and Ctrl/V (paste) them where you want them to reappear.
    Gary Kleiner
    Vegas Training and Tools.com
    Learn Vegas and DVD Architect
    http://www.VegasTrainingAndTools.com
  • Lauraitt
    July 31, 2007 at 8:14 am
    If u use the normal selection tools just press the letter ‘D’ on the keyboard twice to select multiple items.
  • David Shirey
    July 31, 2007 at 9:01 pm
    As a follow-up to that question, is there any way to select all events to end using a key combo? Right-clicking and hitting “n” for “select events to end” is nice, but it only selects in the track you’re on plus any grouped clips. I’d love if Vegas 8 would add something like that, or has someone already done that with a script somewhere?
  • Gary Kleiner
    July 31, 2007 at 10:13 pm
    [davebo] “has someone already done that with a script somewhere?”
    Yes, it is part of Excalibur (the Select Events tool).
    Gary Kleiner
  • Mike Kujbida
    August 1, 2007 at 1:26 pm
    John Rofrano has a Select Events From Cursor script on the VASST site that will select all the events on all tracks that are under the current cursor position and to the right of it.
    It was written for Vegas 4 so you’ll have to open it up in Notepad, change the line that says import SonicFoundry.Vegas; to import Sony.Vegas; and resave it.
  • David Shirey
    August 1, 2007 at 3:13 pm
    Wow that was absolutely what I was looking for, thanks. I’ll search some sites later and see if there’s a way I can bind that script to a key command, but just having it on the toolbar is a nice addition.
  • Edward Troxel
    August 1, 2007 at 4:10 pm
    Yes, it can be added to a keystroke. Just open up the keyboard editing screen and pick that script and assign it to the desired keypress.
    Edward Troxel
    JETDV Scripts
