Activity › Forums › Avid Media Composer › moving media files between media composer and Xpress pro
  • moving media files between media composer and Xpress pro
    Posted by Johnnysouthside on January 11, 2006 at 9:22 pm
    Can anyone tell me if an Xpress Pro system can read Media composer media files? what I’m hoping to be able to do is consolidate a sequence from a media composer system onto a fw hard drive and then load this sequence into an xpress pro system to carry on the edit. will this work? and is there anything I should look out for – compression settings etc.
    cheers in advance
    j
    Johnnysouthside replied 20 years, 8 months ago 3 Members · 3 Replies
  • Richard_victoria_bc_canada
    January 11, 2006 at 9:31 pm
    Hi Johnny,
    Yes this will work if both of your systems are of the same vintage as you need the machines to read the media. ie: nubus, abvb, meridien etc.
    We do exactly what you are wanting to do – and we do it daily between 4 expresses and one media composer, all of which are ABVB.
    Richard
    Still using five Avid ABVB systems.
    Richard Games
    Victoria, BC, Canada
  • Dave Schweitzer
    January 12, 2006 at 5:30 am
    Since Xpress PRO works only with DV25 DV50 15:1s 1:1 (Mojo Required) or various Film Composer resolutions, the Composer media will already have to be at one of those resolutions, or converted on import. From what I remember, Avid broke the conversion feature after AXP version 4.3.5, but I believe I read somewhere that current versions of AXP have restored that feature. If you have time try an OMF export of a portion of your sequence with media consolidated and embedded. Makes for one big .OMF file which contains the timeline and all clips contained therein. On import of this file, AXP will present you with a bin full of all the elements and your sequence as it was when you exported.
    Good Luck and kindly let us know how you fare…?
    DS
  • Johnnysouthside
    January 12, 2006 at 10:44 am
    thanks for all that. I will be buying the latest version of xpress pro for this project, does anyone know if it does support conversion on import.
    I had thought of doing an OMF but since the sequence will be around 90mins, I forsaw problems creating it. I have had systems fall over tring to create just audio OMFs of two hours. anyone regularly make video omfs of this size?
    cheers
    johnny
