Activity › Forums › Adobe After Effects › Moving Mask along a path
  • Moving Mask along a path
    Posted by Twinke on November 15, 2006 at 5:51 pm
    I have an image with a bunch of snowflake swirls on it and I want to have a mask travel along a path to make the snowflake swirls look like wisps of wind. I could keyframe it but then I dont get a constant speed.
    I know I am going to need a bunch of mask but, how does one make a mask move along a path?
    If it is possiable, could you explain in detail how I can acomplish this. Thanks a ton.
    Peter O’connell replied 19 years, 10 months ago 3 Members · 2 Replies
  • Mylenium
    November 15, 2006 at 6:27 pm
    Create your masks on a separate layer and then use that layer as a matte on top of the other layer. You can then easily animate everything using standard transforms for position and rotation.
    Mylenium
    [Pour Myl
  • Peter O’connell
    November 16, 2006 at 6:12 am
    Create the mask, select the mask shape, copy, paste into the position property of the layer with the snowflake.
    Pete
    Thursday; November 16, 2006
    1:12 AM
    barxseven.com
