Activity Forums Adobe After Effects Expressions Moving Layers in 3d around a center point
  • Moving Layers in 3d around a center point
    Posted by Todd on July 7, 2007 at 6:26 pm
    I know this is really easy, but after trying a few things I just can’t seem to get it to work.
    I basically want 7 layers, to move around a center point of a circle at my command and always face the front (not the camera).
    Think of it this way, top view in comp window there is a center point. I have manually placed (couldn’t figure out to do it automatically) 7 layers around the center point based on a reference circle mask. All layers are facing the front view with one layer directly in front of the camera.
    At certain points I basically just want to rotate everything around the center so layer1 that is facing the camera moves around and layer 2 comes up in front of the camera. With some handy DOF added later I’m basically giving the illusion of a 3d ring of layers where one comes up, plays its video, then the whole unit rotates and brings the next layer into view.
    I’ve tried using a null and parenting the anchor points of the objects to this, then simply rotating the null on the y-axis but this obviously doesn’t work.
    Any ideas here? Sorry if my explanation is confusing.
    Todd replied 19 years, 2 months ago 2 Members · 4 Replies
  • Dan Ebberts
    July 7, 2007 at 9:26 pm
    One way – arrange your layers in a circle, position a 3D null at the center of the circle, make the null the parent of the other layers, and add this expression to the y rotation property of the layers:
    -thisComp.layer(“Null 1”).transform.yRotation
    Then animate the null’s y rotation.
    Dan
  • Todd
    July 7, 2007 at 10:14 pm
    Thanks a lot Dan! While that rotated everything around the null, they didn’t continue to face the front. I got it working thanks to another post by adding *-1 to the end of the expression. Works like a charm!
    Thanks again for the help.
  • Dan Ebberts
    July 7, 2007 at 10:30 pm
    You must have left off the minus sign at the front of the expression (does the same thing as multiplying by -1). Glad you got it working though.
    Dan
  • Todd
    July 7, 2007 at 10:37 pm
    My apologies for missing your -, I assumed it was just your indent or way of pointing out the code 🙂 Your method with the – works like a charm as well. Thanks again Dan.
