Activity Forums Apple Final Cut Pro Legacy Moving layer position
  • Moving layer position
    Posted by Charlie Davies on June 3, 2011 at 8:55 am
    On FCP in work I can move a layer by clicking and dragging on it in the canvas window, however at home the only way I can move a layer is by setting the center point in the motion tab. How do I change the settings so I can click and drag layers?
    Both are FCP 6
    Charlie Davies replied 15 years, 3 months ago 2 Members · 2 Replies
  • Christopher Travis
    June 3, 2011 at 1:28 pm
    I’m guessing you need to change your canvas view to “image & wireframe”
    At the top of the canvas there are 3 buttons. The far right button is a dropdown menu of view options. Set that to “image & wireframe” then, if a clip is selected, and the playhead is on that clip, you can drag that layer around the canvas.
    If this isn’t the problem let me know.
    Another tip. Beware the “W” key. This is set by default to toggle between “image” and “wireframe” view modes. I can’t tell you how many times I accidentally hit this and spent ages wondering why I wasn’t getting playback in the canvas.
  • Charlie Davies
    June 3, 2011 at 2:48 pm
    Thanks so much 🙂 Perfect
