Activity Forums VEGAS Pro moving large groups
  • moving large groups
    Posted by Michael O’connor on September 27, 2007 at 5:59 pm
    I have a 12 minute project that needs to have a new section put in the middle. What is the best way to move all the material on all tracks from a point in the timeline, to the right to make room for the interview? I have tried select all, and group but not having any luck. Thanks.
    Edward Troxel replied 18 years, 12 months ago 3 Members · 2 Replies
  • Terry Esslinger
    September 27, 2007 at 6:09 pm
    I routinely use Excalibur to do thatbut I think you can do it by the standard Windows method of holding down the left mouse button and drawing a box around all the events you want to move (thus selecting them) and then moving them.
  • Edward Troxel
    September 27, 2007 at 8:14 pm
    I, too, use the select events tool in Excalibur for most of these things. However, as Terry mentioned, there is a selection tool which will let you select multiple events to be moved. Also, you can use the “Insert – Time” menu option if you know how much time you want inserted. And then there’s always the “Ripple” options. Many ways to perform this task.
    Edward Troxel
    JETDV Scripts
