Activity Forums Adobe After Effects moving keypoints together in the z axis
  • moving keypoints together in the z axis
    Posted by Martin Earle on March 30, 2009 at 8:04 pm
    Dear all!
    I’m have a really annoying problem –
    How do I move a whole 3D layer (including its keypoints) forward in the z-axis? I’ve managed a few times but normally I just move a single keypoint forward in space…. I’ve tried highlighting all the keyframes and then moving the layer in the preview window but I’m rarely lucky with it!
    Thanks for your help!
    Stuart Elith replied 17 years, 6 months ago 3 Members · 6 Replies
  • Roland R. kahlenberg
    March 30, 2009 at 9:59 pm
    Simply select all the keyframes and then scrub the z-value property from the timline.
    Cheers
    RoRK
    broadcastGEMs – AEPro Volume 02 (Professional Adobe After Effects Project Files – Now Available).
    Adobe After Effects Training in Asia.
  • Martin Earle
    March 30, 2009 at 10:30 pm
    Thank you very much although I have tried that and, after selecting all the keyframes, adjusting the z axis setting only adjusts one of the keyframes. It’s maddening!
  • Martin Earle
    March 30, 2009 at 10:32 pm
    Ahhhh…. It does seem to work but only if the ‘current time indicator’ is on the first keyframe of the sequence. Phew. Thanks for your help.
  • Stuart Elith
    March 30, 2009 at 11:07 pm
    Just FYI, it should work as long as your current time is on ANY of the keyframes. 🙂
  • Martin Earle
    March 30, 2009 at 11:16 pm
    not on my machine (although it is new).
  • Stuart Elith
    April 1, 2009 at 3:24 am
    Hmmm, interesting.
    I just checked, and I can indeed rest my time on ANY keyframe and it will work, adjusting by scrubbing a value, or moving it around in the comp window with my arrow, or even nudging with arrow keys.
    I am on CS3 though so perhaps they have changed it (seems like it would be a step backwards in my opinion). Also on a Mac, though you wouldn’t expect that to matter either.
