Activity Forums Maxon Cinema 4D Moving Keyframes?
  • Moving Keyframes?
    Posted by Sam Oxford on June 9, 2016 at 10:02 am
    Hi There,
    I am currently working on a sequence in which a character made in Adobe Fuse/Mixamo jumps off a boat into the water below.
    I have the character, the boat and the water complete and have exported the rig and animations from Mixamo online, an then imported and textured them in C4D but on of them is having a bit of trouble with my moving its keyframes so I can join two animations together.
    Whenever I drag the keyframes down the timeline and then scrub through the animation its as if the rig detaches from the body.
    This mean that the movement is carried out but no extremities move like in the original animation?!
    What can I do to fix this!
    Here is my C4D Project https://f1.creativecow.net/file/10176/10176_infiniteocean.c4d.zip
    I would really appreciate it if someone could explain what I am doing wrong!
    I am new to Cinema so any learning is great!
    Thanks very much!
    Sam Oxford
    Sam Oxford Films
    Corrado Carlevaro replied 10 years, 2 months ago 2 Members · 1 Reply
  • Corrado Carlevaro
    June 11, 2016 at 4:03 pm
    Not sure what your problem is, your scene looks fine. Maybe you are in Point mode (instead of Object mode) and you see your mesh in rest, non animated, position (detached from the rig)?
    Corrado
