Activity Forums Adobe After Effects moving keyframes
  • moving keyframes
    Posted by Thomas Peter on November 13, 2008 at 4:20 pm
    Sometimes selected keyframes just won’t move if I try to drag them along with the mouse, only nudging them forwards or backwards with the keyboard works. Other times they move without problem. There does not seem to any regularity in that. It drives me nuts. What is it? any idea?
    Another related thing: if I change the duration of a layer in the timeline, can I somehow make all keyframes change with it automatically or do I always have to select them as well?
    Thanks so much for your help!
    Tom
    Thomas Peter replied 17 years, 9 months ago 2 Members · 2 Replies
  • Brian Charles
    November 13, 2008 at 7:15 pm
    If you mean move them relative to the original layer’s keyframes you can either make them roving keyframes then reposition them or select all of them and alt/option drag the first or last keyframe into its new position.
  • Thomas Peter
    November 13, 2008 at 8:21 pm
    thank you, Brian. I’ve tried it. it works and makes my work flow a lot easier.
