Activity Forums Adobe After Effects moving key-frames automatically when extending a layer
  • moving key-frames automatically when extending a layer
    Posted by Turgay Uzuncakmak on March 23, 2012 at 9:20 pm
    I have a multiple layers of the same length with Shatter effect on them, each having 2 key-frames only. The placement of the key-frames are different on each layer. When I extend the layers all into the same length all keyframes remain where they are. And I want them to move automatically as I extend the layers?!
    I hope I made myself clear and wish to find an answer asap.
    kind regards and thanks in advance.
    Chris Brett replied 14 years, 5 months ago 2 Members · 1 Reply
  • Chris Brett
    March 24, 2012 at 8:48 pm
    Hi there — this can be done easily – will try and remember – am a bit new to this stuff myself and am not on the kit at the moment so — from memory here goes — its something like ….. drag a box over all the keyframes to select / press the alt key down and hold down / click on any of the keyframes at the end of the current timeline and slide out to new desired length — you should find all the other keyframes slide out proportionally which hopefully gives what you want
    ————– good luck with it all —-chris brett —-
