Activity Forums Adobe After Effects moving image warping
  • Peter Litwinowicz
    January 16, 2007 at 7:16 pm
    Looks like what you are doing in the test footage was the following;
    1) creating a circular matte
    2) generating lines emanating from the circular matte the use the color found on closest point from a given location to the edge off the circle.
    You can use our RE:Fill to do this. It’s intended use is to fill in “dead” pixels, but you can also do cool kaleidascope and ray-type effects with it by simply providing a matte. See the gallery here: https://www.revisionfx.com/rfilgal.htm . Look particularly at the last two examples. There’s a demo version in the Downloads subsection for RE:Fill on our website you can check out. RE:Fill is $99.95.
    Cheers,
    Pete Litwinowicz
  • Aaron Stella
    January 16, 2007 at 9:48 pm
    Actually, there is a plug-in called “light wipe” that will achieve that effect identically. If I didn’t know better, I’d say that’s exactly what they used.
