Activity › Forums › Avid Media Composer › Moving Help!!!
  • Moving Help!!!
    Posted by Liam Stephens on March 30, 2006 at 5:54 pm
    Hi i am having problems with moving multiple clips in the timeline. In FCP i use the “select everything to the right” tool and then move the clips right or left but in AVID all i seem to be able to do is use the marquee which is time consuming and tricky as i’m dealing with 18min reels. Is their an AVID equivalent or a better way to select all the clips to the right of my CTI or cursor.
    cheers
    Liam
    Liam Stephens replied 20 years, 6 months ago 3 Members · 3 Replies
  • Geraint Pari huws
    March 31, 2006 at 9:18 am
    there’s no direct equivelant, either zoom down the time line and lasoo everything and then drag, or if you’r at a butt join, just splice in a bit of filler, or whatever’s in your source monitor but with the tracks deselected. If you need to move it by a specific amount then just pop in a frame of filler hit trim/source and type in the duration of the gap you’re trying to create, sounds cumbersome, but if you know your keyboard you’ll have done it before you can say final cut pro!
  • Jon Zanone
    March 31, 2006 at 12:21 pm
    Make sure your mouse is in the area ABOVE the timeline, but within the timeline window. Hold down the option key (I believe – I’m not in front of the Avid right now) and drag the marquee around your clips. One of the modifier keys puts you in trim, while another performs the action you are seeking. Now that I think about it, you might need the overwrite mode button on. Adjust the size of the timeline to see all your clips (Cntrl/Cmnd ] or [). Keep in mind if you have any black within your selection (even 1 frame) you’ll need to have that selected….
    Jon
    “So you want to throw out the old you – but the old you is old enough to know it won’t make it better”
    Del Amitri – “Make it Better”
  • Liam Stephens
    March 31, 2006 at 7:16 pm
    Thx for your help guys. Well atleast i haven’t been doing my moving in an unusual way seems thats the only way to do it. It’s just weird when working with my boss in FCP its not a problem but when we go to AVID she thinks i’m slow, atleast i can blame the program ;).
    cheers
    L
