Moving from Vegas to FCP
I’m moving a project offlined in Sony Vegas 8 to FCP 5.1. I’ll be recapturing the tapes into FCP and going from there. Need some help in getting the edit across.
Vegas isn’t playing nice:
The EDL export script fails with an “Object required” error.
So I used AAF. Going via Premiere CS3 (Win) gets me the edit with a small glitch in the audio tracks. I exported 1 track at a time to CMX3600 and brought these into FCP.
After capturing a tape I noticed some incorrect footage compared to the video reference. After investigating, some clips come through in the AAF with incorrect timecode (but correct reel number). This isn’t an TC offset problem; the TC is minutes too early or too late, seemingly random depending on the clip.
Remembering the small audio glitch in Premiere, I switch to importing into Avid Express Pro (Win), which initially just pulls the offline clips in but not the sequence (following a NOT_THAT_MANY_BYTES error). Using Vegas’ export legacy AAF to push out 1 video track at a time finally gets it into Avid. Looking at the sequence there I have the same incorrect timecode on problem clips as first noticed in FCP, so there’s no point in going across to FCP via CMX3600.
Looking at the Vegas timeline, I see that many (haven’t checked them all) of the TC problem clips occur from Vegas subclips. The offline editor captured tapes to big .AVI chunks and then split them up using subclips.
I’m wondering if there’re any export ideas I’ve missed?
I haven’t used Vegas til now, but it *seems* to be coy about clip and especially subclip TC when media is offline, so I’m not able to completely confirm that the TC isn’t messed from within Vegas. I doubt this is the case, however, as I’ve used multiple .VEG project files from the offline editor and he’s exported a reference video from the very same timeline.
The Vegas project is 3 video and 3 audio tracks, with video crossfades and speed-ups, all of which came through fine on the first Vegas -> Premiere -> FCP attempt, just the TC is messed.
Is there anything else to do, short of getting the offline editor (with media still linked) to write out an Excel EDL? Anything to do with Vegas’ Media Manager that can force all subclips to become clips perhaps?
Thanks for your time,
Stephen Abbott
sabbott@gmail.com
