Activity Forums Adobe Premiere Pro Moving from firewire to SDI card
  • Moving from firewire to SDI card
    Posted by Chad Treanor on April 6, 2005 at 3:26 pm
    Im thinking of moving from my camera/firewire digitizing method to getting a deck and capture card so I can capture uncompressed DV footage. I’d really like to see if this capture card I have in mind (from Decklink) is worth getting. Its only in the $280 to $300 range and seems like Decklink has the rep. to be a great capture card manufacturer. On the B&H page their summary states that this card works in conjunction w/Premiere Pro and thats what I’m cutting on these days.
    I’d like to also see what kind of deck I would have to purchase to work with this card to achieve uncompressed DV.
    Does capturing with a card like this require more RAM?
    Anything I should look out for with my PC while doing this upgrade? Any advice would be really appreciated.
    Chad Treanor
    Dell XPS
    Windows XP Professional
    Adobe Digital Video Professional Package
    3.2 Ghz processor
    1 gig of ram
    280 gigs of storage
    Paul Carlin replied 21 years, 5 months ago 3 Members · 2 Replies
  • Yummyboo
    April 6, 2005 at 9:53 pm
    DVCAM is compressed when it is shot, there’s no point of using SDI capture on DVCAM footage.
    But if you really wanted to do it for some reason, a used sony DVCAM decks with SDI option like DSR1500 would cost you around 6K
    https://www.tvprogear.com/used-video-buy.php?desc=515
    also you need some sort of raid storage for unpressed SD
  • Paul Carlin
    April 7, 2005 at 8:38 am
    There is no such thing as uncompressed DV or DVCAM, as Vera pointed out.
    The Decklink cards are great, work fine (I have one) and are an incredible steal for an uncompressed SDI capture hardware. However, you will need a source deck or converter that can output SDI. This SDI VTR/hardware is far more expensive.
    The best use of these sub $300 cards is the broadcast monitor output ability while working in After Effects or Premiere. But then, you need a broadcast monitor that supports SDI input, and once again, it gets very expensive again. Unless you are in a post house, this card is not practical.
    If you are shooting DVCAM or DV then I highly suggest you continue using firewire. That will maintain your native signal. While there are advantages to uncompressed SDI in multigenerational compositing, there is minimal improvement, and I don’t see that as practical given your budget. You can achieve the same results by using AE to convert the DV to Uncompressed and work with that.
    If you feel like spending some money then I suggest you get the Decklink SP card for $595. This allows you to go component analog in and OUT with XLR audio and RS-422. You may never hook a deck up to this card for capture, but the external monitoring if priceless. With this card you will be able to hook up the component video output to any affordable broadcast monitor for viewing your AE projects and Premiere timelines (render required for DV footage) on a REAL interlaced monitor. This is crucial to any REAL editing or design work.
    While you may pay more for the card, you will save thousands on the monitor since you don’t need SDI. Sony has 14″ PVM-14L2 Professional Monitor for $1040 on bhphoto. It even has the important 16:9 aspect ratio switch and of course, component video inputs.
