Activity Forums Adobe Premiere Pro moving frame via position with keyboard (left,right,up,down)
  • moving frame via position with keyboard (left,right,up,down)
    Posted by Peter Dj on November 23, 2012 at 7:47 am
    Hello!
    I’ve been doing quite a bit of key framing recently and wondered if there was a way to move the position of a frame (within the videoeffects/motion window) via the keyboard rather than using the mouse to click and drag the frame..
    I’m masking the face of a person and currently am moving frame by frame via the keyboard and using the mouse to move and set keyframes. Wondered if there was an easier way
    Hope that’s clear 🙂
    thanks for your help
    Gabriel Sanchez replied 13 years, 9 months ago 2 Members · 1 Reply
  • Gabriel Sanchez
    November 26, 2012 at 12:29 pm
    You should be able to move the frame up, down, right or left with cursors. Only need to have selected the Motion effect in effect control pannel. If you´re with cs6, then keyboard shortcut in cursors won´t behave this way, so you can then select in keyboard preferences the CS5.5 keyboard, which will allow you to move the frame with cursors, or personalize the CS6 keyboard shortcuts to link this function in other buttons.
    Regards
