Activity › Forums › Apple Final Cut Pro Legacy › Moving footage
  • Posted by Michael Kelly on January 25, 2011 at 10:33 pm
    Hi, I recently tried moving a segment from sequence to another sequence and the footage changed. The segment was the same length but the footage wasn’t the same. Has anyone ever experienced this?
    Michael Kelly replied 15 years, 7 months ago 3 Members · 3 Replies
  • Olin Padilla
    January 25, 2011 at 10:54 pm
    Did you check the frame rates?
  • David Roth weiss
    January 26, 2011 at 9:07 am
    Most likely you need to use remove attributes and check the distort parameter go all clips.
    David Roth Weiss
    Director/Editor/Colorist
    David Weiss Productions, Inc.
    Los Angeles
    https://www.drwfilms.com
    A forum host of Creative COW’s Business & Marketing and Apple Final Cut Pro forums. Formerly host of the Apple Final Cut Basics, Indie Film & Documentary, and Film History & Appreciations forums.
  • Michael Kelly
    February 4, 2011 at 10:03 pm
    Thanks. The problem it turns out is that I imported some PAL footage into the project and wasn’t aware until I started moving sequences. I have since converted the PAL footage to NTSC and reconnected but I still have the same issues with moving the sequences.
