Activity Forums Adobe After Effects Moving footage with greenscreen footage that doesnt move
  • Moving footage with greenscreen footage that doesnt move
    Posted by Marvin Hackfort on July 14, 2014 at 4:59 pm
    Hey,
    I am going to film a little music video in 3 days and I am thinking about how to get this one effect.
    I am going to have a slow camera movement from the left side to the right side of the room.
    Afterwards I want to have a person appear in different spots in that footage.
    The way I wanted to do this was by
    1) film the actual background footage with moving the camera
    2) film the person in front of a green screen in the same room for the same lighting on a tripod
    3) track the background (do i need a 3d tracker?)
    4) use the greenscreen person on the tracked data so he stays where i want him to stay
    does this work or do i need to know something?
    thanks in advance
    Marvin Hackfort replied 12 years, 1 month ago 2 Members · 4 Replies
  • John Cuevas
    July 14, 2014 at 7:21 pm
    I’ve done this effect without a greenscreen. Shoot the clean plate without people. Shoot the person in those locations on a locked down shot, then motion track and insert the person into the clean plate.
    You can the technique a bit in these videos. Mysteryguitarman Looping Effect Tutorial
    Mysteryguitarman McDonalds Commercial
    McDonalds behind the scenes
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Marvin Hackfort
    July 14, 2014 at 7:30 pm
    Okay, so I would basically film the background, then three tripod shots with the people in it, right? and then cut them out or use a green screen, motion track the background and put them in there?
    right? sound so much more complicated than my version but it sounds like its the same or maybe i dont understand :O
    but thanks !
  • John Cuevas
    July 14, 2014 at 8:29 pm
    Nope you got it right, doing it this way, you get the person into the scene vs doing a composite. I’ve done it in the past and done right looks really cool, but it takes some work and practice to execute.
    Your workflow should work for you video, but I would suggest if you can to do some test ahead of time. It will reduce some of the surprises that will inevitably pop up later.
    Thinkck.com
  • Marvin Hackfort
    July 14, 2014 at 8:57 pm
    I planned on testing it tommorow, i will show u how it worked out and maybe u got some ideas to make it better 🙂
