Activity Forums Avid Media Composer moving footage imported at the wrong frame rate into a new project
  • moving footage imported at the wrong frame rate into a new project
    Posted by Laura Dunn on March 1, 2010 at 4:46 pm
    I accidentally imported HD footage shot at 30fps into a 24fps project. The footage was all imported Quicktime movies from a hard drive.
    Edits have already been made, but I noticed that the footage was stuttering.
    Now I want to create a new project with the correct 30fps settings and be able to bring in the bins from the old project, so that I can batch import the media at the correct frame rate. I keep getting errors when I try to do this.
    Any advice?
    Paul Harrington replied 16 years, 2 months ago 2 Members · 1 Reply
  • Paul Harrington
    March 2, 2010 at 2:03 am
    Are you on V4 of Avid, if so and your working in 24p, and the 30fps HD vision needs to be converted. You need to open a 30 project import your QT files then close and go back to your 24p project Open the bin from the 30 project and replace the vision, I don’t if relinking will work but give it a go…Paul H
