Activity Forums Avid Media Composer Moving Footage From Unity to FCP
  • Moving Footage From Unity to FCP
    Posted by Daniel Garriga on July 23, 2009 at 2:16 pm
    Hello all. We have a good amount of footage on our Lanshare Unity drive that we want to move to FCP. I know automatic duck takes OMF files and can convert them to FCP projects but requires you to re online or re digitize. I heard some where there is a utility that allows you to move footage from a Unity to FCP without Re digitizing. Does anyone know of anything like this?
    We have a Lanshare 2 TB Unity running on Avid Media Composer (Version 13.1.1 I believe). Its an old version from 2002 or 2003.
    We would be moving the footage to FCP 6.0.5 on G RAID 1TB or 2TB drives.
    Daniel
    John Pale replied 17 years, 1 month ago 4 Members · 7 Replies
  • 7 Replies
  • Job Ter burg
    July 23, 2009 at 4:32 pm
    I thought that the newer versions of Automatic Duck also convert the media to FCP.
    Your MC is likely to be MC12, BTW.
  • Daniel Garriga
    July 23, 2009 at 6:58 pm
    Hi, thanks for your response! Yes I just checked it is 12!
    I forgot to mention that what we need is ALL footage. ALL raw low res footage BINS captured low res 20:1 on Avid and all SEQ’s that are in Low Res 20:1 and HI RES 2:1. We essentially need to move a whole job (A very big one) from Avid to FCP without having to re digitize every single raw footage tape.
    We’d be moving it from one client to another (in this case, external G Raid drives).
    Thanks.
  • John Pale
    July 24, 2009 at 3:20 am
    Automatic Duck only works with sequences, though the new version will allow you to use Avid media without recapture.
    As for recreating your project structure, with bins….you are kind of out of luck. Nothing really does that.
    BTW…it would be very problematic for you to work without recapture. Avid media is NOT Quicktime…which is what FCP uses. You will not have ANY realtime performance within FCP of Avid media.
    If there is anyway for you to keep this in Avid you should. Trying to make this workable is going to be a nightmare.
  • Job Ter burg
    July 24, 2009 at 11:19 am
    If you need all footage and bins, do yourself a favour, and don’t do it. Or be prepared to start over from scratch.
  • Shane Ross
    July 24, 2009 at 10:16 pm
    Why do you need to switch?
    Shane
  • Daniel Garriga
    July 29, 2009 at 8:43 pm
    Well we are moving to a smaller office space and the plan is to only bring one Avid and have 2 Final Cut Stations as our main workstations. So, we thought about moving one job completely over to Final Cut but without re digitizing and keeping all clipped out and logged bins in tact.
    Also, in regards to moving an Avid (and getting rid of Two) to another location am I wrong to think that this requires a job of an Avid Engineer to come in and disconnect and re connect our system (patch bays also) in the new space we get? I look in our machine room and the wiring for blackburst, unity, and patch bays is beyond my knowledge.
  • John Pale
    July 30, 2009 at 3:27 am
    [Daniel Garriga] “I look in our machine room and the wiring for blackburst, unity, and patch bays is beyond my knowledge.
    If that’s beyond your knowledge, then yes…bring in someone who does this for a living. This is your business you are talking about. If things don’t work right you lose money….and its harder to fix stuff once you start using it. Make sure its set up right from the beginning….in the end you save money.
