Activity Forums Apple Final Cut Pro moving FCP library without the connected media
  • moving FCP library without the connected media
    Posted by Tony Peck on June 13, 2014 at 12:34 am
    I would like to either move the Library or the projects if it is possible to another hard drive. My problem is the Library is very large. I would like to send a project or Library without any media in it and I’ll reconnect the media later. Is this possible?
    Tony
    Jeremy Garchow replied 12 years, 3 months ago 2 Members · 1 Reply
  • Jeremy Garchow
    June 13, 2014 at 5:22 pm
    Is the media managed, generated, or external?
    If it’s managed, you’ll have to consolidate the media out of the library, then make a new library on the destination hard drive, then drag what you want from the current library to the new one (or select what you want and use the File >Copy…. commands.
    If it’s generated or external, so the same as above without the consolidation step.
    Jeremy
