Activity › Forums › Apple Final Cut Pro Legacy › Moving FCP Associated Files
  • Moving FCP Associated Files
    Posted by Leena Patel on September 26, 2010 at 1:32 am
    I’ve just bought Final Cut Studio and I’m trying to use the least amount of hard drive space on my computer. I want to move the associated files for Final Cut (located in Macintosh HD > Library > Application Support > Final Cut Studio) to an external drive and reconnect the files to the new location. However I do not know where on Final Cut Pro I can do that. I’ve tried System Settings, User Prefs, Audio/Video Settings.
    Am I looking in the wrong place or is moving the files a bad idea/impossible?
    Ben Holmes replied 16 years ago 4 Members · 3 Replies
  • Chad Tingle
    September 26, 2010 at 4:09 am
    Are you trying to move your media files or the program files associated when you instal Final Cut?
    Chad Tingle
    Producer/Editor
  • Bret Williams
    September 26, 2010 at 6:18 am
    Why don’t you just move them and see what happens? You can always move them back. I moved mine. I think it just complained and asked where they were. I pointed the apps in the right direction. Soundtrack was a problem for some reason and I had to leave them. But Motion and DVDSP I moved to a separate drive.
  • Ben Holmes
    September 26, 2010 at 4:49 pm
    You can run FCP completely off an external drive AFAIK – I seem to remember reading a couple of editors saying they did this when working in some facilities so the version they used was correct and set up as they wanted it.
    To do this you would have to choose this drive as the install location when you installed all the software. Moving system resources after installing sounds like it either wouldn’t work, or would cause endless problems. Certain things, like the preference files would simply be re-written in the original location anyway.
    Edit Out Ltd
    FCP Editor/Trainer/System Consultant
    EVS/VT Supervisor for live broadcast
    RED camera transfer/post
    Independent Director/Producer
    https://www.blackmagic-design.com/casestudies/detail.asp?case=therydercup
