Activity Forums Media 100 MOVING EFFECTS STUTTER WHEN EXPORTED TO QT AND BURNED ON DVD
  • MOVING EFFECTS STUTTER WHEN EXPORTED TO QT AND BURNED ON DVD
    Posted by Daniel G on March 28, 2006 at 6:43 am
    I USE MEDIA 100 (8.2.2) AND MAC OS 10.3.9 AND QUICKTIME 6.5.2
    WHEN I EXPORT 468X720 VIDEO WITH MOVING EFFECTS (PUSH, PAGE TURN, SPIN) GENERATED IN MEDIA 100 TO A QUICKTIME FILE AND THEN BURN THAT FILE ON A DVD THE EFFECTS STUTTER, TURN INTO DIGITAL BLOCKS AND LOOK LIKE SHIT — ALMOST LIKE THERE IS A FIELD ORDER PROBLEM. BUT WHEN I MASTER TO TAPE THEY LOOK GREAT!!! ANYONE ELSE HAVE THIS PROBLEM? A FIX?
    THE ONLY WAY I CAN OVECOME IT IS TO EXPORT SOURCE VIDEO TO AE AND RECREATE THE EFFECTS IN FRAME (NOT FIELD) MODE. THEN THEY LOOK GREAT.
    DG
    Neil Smith replied 20 years, 5 months ago 3 Members · 2 Replies
  • Floh Peters
    March 28, 2006 at 4:46 pm
    This sounds like
    a) your Caps lock key seems to stick
    and b) you
  • Neil Smith
    March 28, 2006 at 5:41 pm
    I two have a similar stutter on panning & 3 D titles when moving
    in from either side.
    I use bitvice,Media 100i 8.2.2,DVDSP
    I have just upgraded to 8.2.2 from 7.5 using OSX 10.3.9
    G4 1.25 GHz 1.75 RAM.
    The reason to upgrade is to out put to DVDSP.
    Have been using FCP to out put to DVDSP with no problems
    Even used the same footage in FCP and all works fine
    Have tried exporting from Media 100i by-referance, Self-contained,
    Quicktime etc., Makes no differance.
    Have posted same message on Bitvice forum under jagged video
    It was posted yesterday so still waiting replies
    Any thoughts or help greatfully appreicated
    Neil Smith
