Activity › Forums › Apple Final Cut Pro Legacy › Moving edited text from After Effects into FCP !?
  • Stephen Smith
    July 5, 2012 at 10:39 pm
    Export the comp out as a Prores 4444 or Animation if you want to keep the background transparent. Be sure to set the Channels to RGB + Alpha. Then make sure depth is set to Millions Color +. Hope this helps and best of luck.
    Stephen Smith
    Utah Video Productions
    Check out my Vimeo page
