Activity › Forums › Avid Media Composer › moving DNxHD files made in Sorenson Squeeze to the Avid MXF folder
  • Amy Murray
    September 21, 2013 at 12:55 am
    Ok, thanks you have really bren a big help. Just one last question… how do you access your internal scopes in v7? Maybe it has changed and I just can’t find them, regardless of what the ted. guy said. (He said I would need symphony and they are no longer available in v7)
    Thanks again and again!
    Amy
  • Michael Phillips
    September 21, 2013 at 1:02 am
    The way I always have. I got to color correction mode and change one of the three monitor views to one of the scope views. In my case, the one on the right.
    Michael
  • Michael Mccune
    September 23, 2013 at 12:05 am
    Yes, little mention of scopes in MC7 but they are where they were previously: in the source/record monitor window title bar’s drop-down menu.
    The Avid Learning Series, three volumes, has a section on media management, as does the book, Avid Agility, by Steven Cohen.
    Regarding media management, one very interesting view–and it includes a detailed tutorial–is at Douglas at Gaijin-Eyes, https://www.gaijin-eyes.com/2014/2014_MediaManagement.html.
    These tutorials, and his many others on MC, are not free but the cost is very reasonable–coffee at Starbucks for a couple of days– for a detailed, expert perspective. The site also approaches many other facets of MC and FX. With a Scottish accent! And the visual presentation is expert as well; they are much better than any other tutorials I have seen.
    Good luck!
    Mike
  • Amy Murray
    September 23, 2013 at 2:07 pm
    Thanks, I will check out the books and maybe the tutorials. I have seen quite a few tutorials but have always been hesitant to spend the money and follow their lead, not knowing if it is actually a good way to work. But, if you guys recommend this particular one, it must be ok!
    Best,
    Amy
  • Glenn Sakatch
    September 24, 2013 at 2:03 pm
    Have you tried doing a fast import? The files out of FCP are Pro Res, and you are on a Mac – correct?
    Do you need them to convert to DNX?
    Glenn
  • Amy Murray
    September 24, 2013 at 3:49 pm
    Yes, I am on a mac, they are Pro Res and I am converting to DNX. I just tried an import and it seems to work. Is a “fast import” any different than going to import under File?
    thanks!
    Amy
Page 2 of 2
