Activity Forums VEGAS Pro moving dashed lines in Vegas 16
  • moving dashed lines in Vegas 16
    Posted by Faisal Noway on September 20, 2018 at 7:24 pm
    Hello,
    it will be Really helpful to let me know how to make moving dashed lines in Vegas 16
    like this one here:https://www.youtube.com/watch?v=I59emqYCeDE
    I know its a Tutorial but i doesn’t work for me
    John Bolton replied 7 years, 7 months ago 2 Members · 3 Replies
  • John Bolton
    September 21, 2018 at 7:52 am
    Which part does not work for you… I have just tried it and it works fine.
    Make sure that the WHITE outline you draw is saved as a PNG file.
    The line is NOT drawn on the actual picture so you have two images on the time line.. One of the face and the other of the white outline.
  • John Bolton
    September 21, 2018 at 4:57 pm
    If you still have a problem then here are 2 veg files.. One was done in V10 which can be opened in higher version or there is also a V16
    12737_lines.zip
    It will look like this
    https://www.youtube.com/watch?v=ZsCXhYUFgng
    Hope this helps if you can’t sort it
  • John Bolton
    September 23, 2018 at 7:29 am
    Hello Faisal. Did this help?
