Activity Forums Adobe After Effects Moving composition from one project to another…
  • Moving composition from one project to another…
    Posted by Stephen Barrante on March 24, 2008 at 10:35 pm
    I have a situation where I have two separate after effects projects and would like to move one of the composition (with all assets that belong to it) into the other .aep.
    I thought I could copy the composition, open up the other project and paste. But no luck. This is something I do regularly in flash, and those files are just as complex. And since most of these assets are references to the real media, I figured that would just work. Not so much. The problem is many of the assets are very similar or the same in both .aep’s. So, it became apparent to me after the fact that I should have just created two compositions in the same project.
    Any advice?
    Daniel Oliveira prins replied 9 years, 2 months ago 5 Members · 4 Replies
  • Aharon Rabinowitz
    March 26, 2008 at 2:43 am
    I might be missing something – it’s late and I am wiped out – I’d open a blank comp and import both AEP’s into it (You can choose File > Import > File, and AE project is one of the options).
    Then twirl everything down until you find the 2 comps you want to keep.
    Select File > Reduce Project
    Everything not related to these 2 projects will be removed.
    If you have any duplicate references to the same file, this next step will clean that up:
    File > Consolidate all footage.
    Then just reorganize the stuff in the project panel.
    If you need to understand this better, check out these 2 tutorials:
    Importing Projects:
    https://library.creativecow.net/articles/rabinowitz_aharon/Workflow_7.php
    Cleaning up your projects (in a tutorial on multi machine rendering):
    https://library.creativecow.net/articles/rabinowitz_aharon/multi_machine_rend.php
    Aharon Rabinowitz
    Email: arabinowitz (AT) yahoo (DOT) com
    All Bets Are Off Productions, Inc.
    Creative Cow After Effect Podcast
    Internet Killed the Video Star: A Guide to Creating Video for the Web
  • Alex Tsakiris
    March 27, 2010 at 1:14 pm
    perfect… many thx for sharing this.
  • Keith Neuendorff
    December 10, 2010 at 8:23 pm
    On a somewhat related note…
    Using the import (as suggested in one of the above referenced tutorials) is a good way to move Compositions between projects to make them “behave” better and not cause AE to crash.
    My specific case was that I had a project that kept getting more complex and ended up where it would not open successfully on my laptop (a decent Core2 Duo Windows machine but with only 3Gig of RAM). To fix this I opened AE with no initial project and did an import on the project that would not normally open. AE complained a bit with some popups but did succeed in opening the project. I cleared out about half of the compositions and media, saved the project under a new name. I repeated this to recover the other half of the compositions and now all of the projects work nicely again.
    One nice additional tip is that if you start deleting compositions from an imported project, I suggest clearing out the Render Queue because AE complains and then sometimes crashes the next time it tries to open the project when it finds references to previoiusly rendered items in the Render Queue that no longer exist in the Project.
    Keith Neuendorff
    Tiny Robot Media
    Austin, TX
  • Daniel Oliveira prins
    June 21, 2017 at 5:24 am
    Use save comp as project script. And import your project into a new project.
