Activity Forums Adobe Premiere Pro Moving clips up or down from track to track
  • Moving clips up or down from track to track
    Posted by Spencer Tycksen on May 5, 2014 at 6:28 pm
    In FCP you can hold shift when moving a clip up or down tracks, and that keeps it from moving left or right. Is there a similar option in Premiere?
    Walter Soyka replied 12 years, 4 months ago 2 Members · 1 Reply
  • Walter Soyka
    May 5, 2014 at 8:27 pm
    [Spencer Tycksen] “In FCP you can hold shift when moving a clip up or down tracks, and that keeps it from moving left or right. Is there a similar option in Premiere?”
    As long as snapping is on (S), the clip will stay horizontally constrained while you move it up, unless you make a large enough horizontal movement to clear the snap target. In other words, with snapping on, just forget about the shift key and it generally will work as you expect. You can even toggle snapping with the S key while you’re dragging the clip.
    Premiere Pro CC adds a keyboard shortcut for moving a clip up and down: Alt+UpArrow and Alt+DownArrow. I’m not in from of a Mac right now, but I assume it’s the same there (Alt/Option key plus up/down arrow).
    Walter Soyka
