Activity Forums Adobe Premiere Pro moving clips from timeline to project for later use
  • moving clips from timeline to project for later use
    Posted by Bill Redway on August 4, 2009 at 6:16 pm
    I’m using PPro2. I often want to prepare a clip for later use, possibly a number of interview clips to be cut into action sequences. I cut the rough clips in the Source window from the master tape held in Project, drop these clips onto a Sequence in the Timeline, trim them up, maybe removing breaths, er’s & um’s, adjust volume and eq, etc, then want to drop them into a bin in the Project window ready for later use as I build up the action sequence. But I can’t figure out how to do this last thing, or if it is at all possible. That is, how can I drop clips that have been changed in the timeline back into a Project bin?
    It seems like a very normal and obvious thing to want to do, so is there a way? If not, what can anyone recommend as a workaround?
    Many thanks,
    Bill
    Bill Redway replied 17 years, 1 month ago 3 Members · 4 Replies
  • Vince Becquiot
    August 4, 2009 at 8:33 pm
    You would have to export each clip, since these are no longer the original files, meaning they would have to be rendered anyway.
    CS$ makes that task simpler using batch encoding through AME.
    Most of us us use subclips, but that would be for single in and out cuts.
    Vince Becquiot
    Kaptis Studios
    San Francisco – Bay Area
  • Bill Redway
    August 5, 2009 at 6:48 pm
    Thinking about this a bit more, I guess what I am looking for is ‘Render & Replace’ for video. Why is it only available for audio?
    Bill
  • Diego Pocovi
    August 10, 2009 at 10:48 pm
    This is a feature I really miss from my DPS Velocity and I have been wondering the same thing,, from my Velocity I just press f to a edited clip and will send it to your bin in many ways same clip.
    In premiere what I am doing is to copy -paste to an aditional Secuence, I call Stuff, to use it later.
    I hope works, Diego
    Diego
  • Bill Redway
    August 11, 2009 at 11:13 am
    Hi Diego, Yes I do something similar, adding bits and pieces to a different sequence for later use. But why doesn’t PPro have a better way? Why not Video Render & Replace? Anyone from Adobe like to comment?
    Cheers, Bill
