Activity › Forums › Avid Media Composer › Moving clips from one sequence to another
Posted by Nicholas Neal on May 4, 2013 at 1:34 amHey,
I’m a new user for Avid Media Composer and I’ve been workin in multiple sequences for a project and am trying to take edited clips from one sequence to another. I know in Final Cut this is done by a simple drag and drop, but I don’t know how it’s done (or if it even can be done) in Media composer.David Gaudio replied 11 years, 8 months ago 6 Members · 6 Replies -
Shane Ross
May 4, 2013 at 4:16 amHighlight the tracks you want to copy over. Mark in and out. Press “C”. This will copy to the clipboard. Then go to the Preview Monitor menu and choose Load From Clipboard. Or hold Control Opt when pressing C and it’ll do this.
Mark in on your destination. Choose track destination. Insert or overwrite edit.
Or…Use the select Arrow (red one) to select the clips, or draw a box around the ones you want (upper left to lower right), and then Copy. Go to the new sequence, Paste.
Shane
Little Frog Post
Read my blog, Little Frog in High Def -
Jef Huey
May 5, 2013 at 2:31 pmThe way I would do this is to load the “source sequence” in the source window, Mark In and Out, go to the record window, Mark In, set track patching the way you want and then insert or overwrite as needed. Unlike other systems, this does not make a nested segment, it does what you asked to do. Many advantages of this method in my opinion.
Jef
Jeff Kay
May 17, 2013 at 6:49 amAnd if you want another way to do it, select the part of your sequence with in and out, then hit ctrl+alt+c which will pop just that selected part into the source monitor. From there you can put it into other sequences, but it will also let you put that selection back into the sequence from which it came, which you cannot do if you load the source sequence.
Olivier Prudhomme
September 11, 2014 at 6:17 amThis is one of Avid’s flaw.
So many keystrokes and mouse moving for something that requires 3 or 4 in FCP….
