Activity Forums Apple Final Cut Pro Legacy Moving clips from Avid Express to FCP
  • Moving clips from Avid Express to FCP
    Posted by Tom John on October 3, 2005 at 9:04 pm
    Hi, all,
    I need to capture material from Beta SP in an Avid Express Pro (PC) bay and move it via a portable LaCie drive to a FCP computer elsewhere for editing.
    Will FCP read DV25 OMFI files? Will the firewire drive be writeable from the Avid and then readable from FCP? Or must everything be captured in the Avid as OMFIs, then exported as quicktimes? Any way to embed timecode?
    Thanks!!
    – Tom
    DesertVideo@earthlink.net
    Tom John replied 20 years, 11 months ago 3 Members · 6 Replies
  • Eli Mavros
    October 3, 2005 at 9:50 pm
    It is a bit time consuming, but less so if you don’t start editing on the Avid and only use it for capture. No you cannot import the OMF files; you will have to export quicktimes. You can stripe the quicktimes and import Avid bins if you use sebsky tools…https://www.dharmafilm.com/sebskytools/
    best,
    eli
    Eli Mavros
  • Tom John
    October 3, 2005 at 10:14 pm
    Thanks, Eli. Will Sebsky encode TC in a PC-based Avid?
    – Tom
  • Debe
    October 3, 2005 at 10:22 pm
    The biggest issue you’re going to have is that FW drive will need to be formatted so the PC can see it, and FCP doesn’t like that. It needs it’s media drives formatted HFS+, which a PC will not read.
    debe
  • Tom John
    October 3, 2005 at 10:25 pm
    I’ve been using this LaCie drive with my FCP. Could PC-generated quicktimes still be dragged to it, or will it not interface at all with a PC?
    – Tom
  • Debe
    October 3, 2005 at 10:30 pm
    If it’s formatted HFS+, the PC will not see it.
    If you don’t know, and you’ve been using it successfully as a media drive with FCP, then it probably is formatted HFS+
    debe
  • Tom John
    October 3, 2005 at 10:34 pm
    Thanks for the feedback, guys!
    Best,
    Tom
