Activity Forums Apple Final Cut Pro Legacy Moving clip, not playhead
  • Shane Ross
    December 31, 2014 at 10:03 pm
    Yes…click on the clip and hold OPT, then use the arrows to move it back and forth. If it’s between other clips…this won’t work, you’ll get a clip collision alert. If you want to SLIP the clip, so that the start and end points of it change, but it stays still, then you use the < and > keys for that.
    Shane
    Little Frog Post
  • Pat Trimmer
    January 1, 2015 at 6:11 am
    Thank you!
