Activity Forums Adobe Premiere Pro moving clip in timeline
  • moving clip in timeline
    Posted by Brian Norris on August 22, 2006 at 3:56 pm
    Hello, I’m currently using Pro 2.0 and I would like to move the physical location of my clip in the timeline by 1 or 2 frames for example. If I use the arrow keys it only moves the marker in the sequence. Is there a way to nudge my entire clip to move it in the timeline without clicking and grabbing it? Thanks!
    Brian Norris replied 20 years, 1 month ago 3 Members · 3 Replies
  • Aanarav Sareen
    August 22, 2006 at 6:35 pm
    Not really. If you do want to move/shift the entire timeline over, use the Move tool (keyboard shortcut: M) and then move the clips. To move clips on more than one track, hold down Shift and that will move the entire content of the timeline over.
    Aanarav Sareen
    premiere@asvideoproductions.com
  • Craig Howard
    August 22, 2006 at 8:22 pm
    Select clip and then ALT-Arrow should nudge thge clip 1 frame either way
    Shift – Alt – Arrow should nudge it 5 frames or what ever you set in preferences
    Craig Howard
    Shooter Film Company
    Auckland
    New Zealand
    (Premiere Pro 1.5 / Matrox TRX100 XTreme Pro)
  • Brian Norris
    August 23, 2006 at 3:55 am
    That’s what I was looking for. Thanks!
