Activity Forums Adobe After Effects Moving Clip in Timeline
  • Moving Clip in Timeline
    Posted by Brian Norris on August 30, 2006 at 5:16 pm
    I have a 15 second clip. I only want to use from second 4 to second 8 (4 seconds) so I created an “IN” and “OUT” point to correspond with that timeframe. I now would like to move the entire clip forward in the time line so the “IN” point of this layer matches the “OUT” point of the layer above it. The clip seems to be moving in the timeline but my “IN” and “OUT” points are not moving along with the clip. They seem to be static. Is there a way to move a clip in the timeline and have it’s “IN” and “OUT” points stay relative to the clip and not the composition? Thanks!
    David Rodriguez replied 20 years ago 2 Members · 1 Reply
  • David Rodriguez
    August 30, 2006 at 6:54 pm
    If you select the layer and go to where you want the IN to be and press the “[” key the layers in point will jump to that location.
    You can also nudge the layer into position using
    Option/Alt Page Up = Left 1 frame at a time
    Option/Alt Page Down = Right 1 frame at a time
    Option/Alt SHIFT Page Up = Left 10 frames at a time
    Option/Alt SHIFT Page Down = Right 10 frames at a time
    I hope this helps
