Activity Forums Adobe Premiere Pro Moving Between PC and Mac
  • Moving Between PC and Mac
    Posted by Pat Ford on November 5, 2009 at 8:20 pm
    I have a project coming up…I like to assemble the clips, do a rough cut and then pass it to my editor. The problem is that I am on a pc and my editor uses Final Cut. Premiere was supposed to have an export to Final version in CS4 but so far that has not materialized.
    We have used EDLs to move the project over, but this was met with limited success. I can’t count on the export to Final Cut function showing up as it was promised.
    I presume if my editor had Premiere on his Mac he would be able to open it and edit. I believe you can do this in After Effects.
    Pat Ford replied 16 years, 9 months ago 6 Members · 10 Replies
  • 10 Replies
  • Ninetto Makavejev
    November 5, 2009 at 8:37 pm
    Premiere, like the rest of the CS4 Suite, is cross-platform: so your PremProj from the PC will open on the Mac. You may have to re-link the media if drive paths are different.
    But beware(!) if you e.g. are capturing on either platform in exclusive codecs… i.e. if you capture HDV on Mac you will not necessarily be able to edit the files on your PC… since the Quicktime HDV codec will not be installed by CS4 on a PC… etc.
    good luck,
    ninetto
  • Alex Udell
    November 5, 2009 at 10:33 pm
    I’ve been doing some reading….
    and it appears that the Cineform Codecs are cross platform compatible.
    could be a good solution for at least standardizing the source material.
    Alex
  • Pat Ford
    November 6, 2009 at 4:48 am
    I don’t understand how one sets Cineform to be used as the codec.
    Also, I had trouble moving material from my pc to the Mac via an external hard drive. I was told to format the hard drive with a program (Mac Drive?) But it still froze up the Mac.
  • Ninetto Makavejev
    November 6, 2009 at 9:30 am
    Hard to understand what your problem is.
    What version of OSX are you running? OSX understands (reads) all PC-drive formats excepting some RAID arrays. It can write to FAT32 PC-drives and with the help of Paragon’s tool can also write NFTS drives.
    On the PC side you will need MacDrive to read/write Apple HFS-formatted drives. Both MediaFour MacDrive and Paragon NFTS work fine for cross-platform solutions.
    good luck,
    n.m.
  • Pat Ford
    November 6, 2009 at 7:23 pm
    I am on XP….I hope I will be getting a Windows 7 machine in the next few months.
    I am not sure what Mac OS my editor’s machine is using; however, it never worked with a MacDrive formatted external hard drive from my machine. It locked up.
    I still don’t understand about using the Cineform codec…where do you choose the codec in Premiere.
  • Mark Hollis
    November 6, 2009 at 8:32 pm
    OK, you are going from Premiere Pro to Final Cut Pro, so you need to find a way to transfer the Project into an XML file that the Apple application can read.
    You can export your Premiere Pro sequence as an AAF (advanced authoring format) from the application. There are some things that won’t translate, but the link will detail those things.
    Apple’s Final Cut Studio 7 will import AAF files (also exports them).
    You are limited, in some cases, to a 2G AAF file if you are trying to include media in that file. But Final Cut should be able to batch-capture all of your media.
    As to re-linking media, I cannot say that Final Cut will re-link. But an Apple Macintosh that runs OS X 10.5 or 10.6 can read all PC-formatted disk drives. Your Final Cut Pro editor should transfer all materials to his or her own drives (or array) on the Final Cut workstation and not work off a FAT 32 or NTFS drive, as FAT 32 limits file sizes to 2 Gigabytes and NTFS may not be supported in Final Cut Pro.
    Do some tests first.
    Also, do not anticipate that Adobe Premiere Pro will work under Windows 7. There are at least two people in this forum with bad Windows 7 experiences with Premiere Pro.
    What if there were no hypothetical questions?
  • Richard Depaso
    November 12, 2009 at 7:11 am
    I am having a big problem with Premiere and Windows 7. Once we updated to Windows 7 the machine won’t read MOV files of any sort. I get an “Error 1856” if I try to open a MOV file. Itunes plays them fine but Quicktime Player won’t even open. We have version 7.6.4 quicktime installed, with the Quicktime Pro registration. We also have the Quicktime MPEG2 plugin installed. We’ve uninstalled and reinstalled. Tried loading a 64 bit Itunes download we had and just today the latest on the Apple Quicktime download site which is only 32 bit. Premiere Pro is updated to 4.2 Nothing works.
    Machine is quad core AMD 9950
    8Gig Ram
    Windows 7 Ultimate 64 Bit.
    Richard DePaso
    creators@computer.net
  • Jon Barrie
    November 12, 2009 at 10:01 am
    Have you tried to roll back QT to a 7.5.x version. I find QT always ruin something with every couple of updates and rolling back a couple of versions work fine.
    I’ve Been using win7 and ppro with qt files since RC 7100. I am running with 7.6.4 and haven’t had a problem yet?…
    Jon Barrie
    aJBprods
    http://www.jonbarrie.net
  • Mark Hollis
    November 12, 2009 at 4:06 pm
    If you are looking for an old version of Quicktime, you can find it here.
    For Quicktime Pro owners: Be sure you save your Quicktime Pro registration number before you roll back your version so that you can apply the registration to the earlier version and not have to buy Quicktime Pro again.
    I would not have been so eager to upgrade to Windows 7 on my computer if it were used for actual production or post-production work.
  • Pat Ford
    November 24, 2009 at 7:31 pm
    I have it on very good authority that development is proceeding on the export to Final Cut functionality in Premiere Pro.
    See recent posts in the Adobe forums on this topic.
