Moving audio as video moves
Posted by Doyal Gudgel on August 24, 2011 at 3:20 amWhat is the command that automatically moves the related audio with the video if video is cut from the project or moved.
Doyal Gudgel replied 15 years ago 2 Members · 2 Replies -
John Rofrano
August 24, 2011 at 4:23 am[doyal gudgel] “What is the command that automatically moves the related audio with the video if video is cut from the project or moved.”
By default the video and audio are grouped. When you delete one, the other gets deleted. When you move one the other gets moved. When you cut/trim one the other gets trimmed/cut too.
If this is not the behavior you are seeing, then you either have Ignore Event Grouping turned on. You can toggle it off with Ctrl+Shift+U. Or you have Ungrouped the events. You can re-group them by selecting both events and pressing the ‘G‘ key.
~jr
http://www.johnrofrano.com
http://www.vasst.com -
Doyal Gudgel
August 24, 2011 at 4:06 pmFantastic! I knew it was something like this. It’s always grouped together and I never had the problem. Looking into locking had no solution and I didn’t know I had to look into “grouping.”
I’m not getting my notification in my email of answers which I will have to look into. Sorry for being late acknowledging your response.
