Activity › Forums › Adobe After Effects › Moving Assets in the OS without Breaking Link Inside AE?
  • Moving Assets in the OS without Breaking Link Inside AE?
    Posted by Kevin Camin on October 22, 2012 at 4:36 am
    This issue has always bothered me. Sometimes mid project I’ll want to reorganize the files in my Finder or move them to a RAID or something, and it can be a hassle to reconnect them inside the program.
    Is there a 3rd party app or script that allows you to move the file from inside AE so that the file path changes on the fly?
    Best regards,
    Kevin Camin
    Kevin Camin replied 13 years, 11 months ago 2 Members · 3 Replies
  • Kevin Camin
    October 22, 2012 at 5:12 am
    At the end of the project I run a ‘Collect Project’ command, and archive everything nicely.
    But as a standard practice, I don’t like to keep everything within a folder structure where the AE file is being held. I have a ‘renders’ folder on another part of my drive where I render my Cinema 4D files to. And my video footage is often kept on a RAID. I also have a sizable stock library and keep those assets in another area and am not keen on the idea of duplicating the file on my system in order to move a copy of it to the AE folder.
    Another reason to separate things into different areas is that I run two different online back-up synchronizations and don’t want to back-up all the assets online. For instance the video files are physically backed up and stored off-site. It would take weeks sometimes to back them up online for a single project.
    Best regards,
    Kevin Camin
  • Adam Taylor
    October 22, 2012 at 9:34 am
    You have already mentioned the most obvious way – use the “Collect Project” and instead of manually shuffling your files, get AE to put them in a logical place.
    As Dave said, its not wise to move files around.
    What i don’t understand is why, if you keep your files in the places you have suggested, that you would feel the need to re-locate files in mid-project. Thats just creating more work and more potential for losing stuff.
    Adam Taylor
    Video Editor/Audio Mixer/ Compositor/Motion GFX/Barista
    Character Options Ltd
    Oldham, UK
    http://www.sculptedbliss.co.uk
    My YouTube Animations Page
  • Kevin Camin
    October 22, 2012 at 9:25 pm
    You make a good point.
    I need a more organized system. Things can get a little sloppy during a large project because I’m working with other programs that are rendering a large numbers of assets for use in AE–I tend to organize them in a certain, convenient way while in the heat of things, then consolidate them later, when I’m trying to clean up the Finder. There are other situations I can’t really think of currently that cause me to want to move things around later. But I agree, this is a workflow issue.
    Best regards,
    Kevin Camin
