Activity › Forums › Maxon Cinema 4D › Moving Anchor Points?
  • Moving Anchor Points?
    Posted by Kyle Sowden on August 7, 2011 at 7:16 pm
    I’m in C4D, i’ve made a spinning circle coming from one direction then text spins in from another direction to ‘stick to’ it.
    But now I want to spin the circle AND the text away together. But they’re anchor points are in different places.
    How would I change them?
    Or how would I keyframe a ‘group objects’ because this seems to have the same effect, but messes with my earlier keyframes
    Kyle Sowden replied 15 years, 1 month ago 3 Members · 8 Replies
  • 8 Replies
  • Adam Trachtenberg
    August 7, 2011 at 10:31 pm
    Probably the easiest way would be to put both objects inside a null. Animate them separately for the individual movement and then animate the null to move both together.
  • Kyle Sowden
    August 8, 2011 at 4:09 am
    That sounds like it would work 😀 I’ll try that now
  • Kyle Sowden
    August 8, 2011 at 4:45 am
    Okay, i’ve tried what you said and it seems to work, except for the fact that the anchor, or rotation point is always at the bottom of the circle. I need it at the centre of the circle.
    Even when I change the anchor point with the object axis tool, the circle just jumps up so that the anchor point is still at the base of the circle
  • Steven Mackenzie
    August 8, 2011 at 7:03 pm
    Try setting your timeline to frame 0, create a new Null Object, set its position to the center of the circle (or where ever you want the anchor point/rotation point to be) then make the object that you want to rotate a child of the Null by dragging it under the layer.
    At this point I used a little xpresso to link the object. Right click on the rotation property you animated in the main circle, select “Animation > Set Driver” then select the same rotation property in the null, right click it and select “Animation > Set Driven”
    Let me know if this helps at all. I’m also attaching the file I used to trouble shoot.
    Cheers!
    Steve
    2758_cubes.c4d.zip
  • Kyle Sowden
    August 9, 2011 at 5:59 pm
    Sorry, as soon as I add the objects under the ‘null object’ the objects jump on top of the null’s anchor. so It’s impossible to centre the anchor :/
    I’ll look at that file now
  • Kyle Sowden
    August 9, 2011 at 6:00 pm
    And I tried opening the file and “picture viewer cannot open file” appeared?
  • Steven Mackenzie
    August 15, 2011 at 5:36 pm
    Yeah, I just read up and discovered that c4d r 12 doesn’t have a legacy save mode. Sorry man, keep plugging away. You’ll figure it out.
  • Kyle Sowden
    August 15, 2011 at 11:46 pm
    Damn in. Thanks for all your help though (: I’m sure I will eventually
