Moving an object along a curved path
Posted by Roger Read on April 4, 2013 at 4:52 pmI am trying to get a ball to bounce across the background in a reasonably lifelike manner. Using Pan/Crop, I can get it to progress in a series of triangular lurches, but can’t work out how to get a smoother, curved path.
Is there a simple way in Vegas Pro to do this without resorting to inserting lots of keyframes? Or is there a plug-in which will let me do it?
Roger Bansemer replied 13 years, 5 months ago 5 Members · 6 Replies -
Roger Bansemer
April 4, 2013 at 5:50 pmPretty sure there’s no way to do it without a lot of key frames and I know of no plug-in that will do the trick either.
Roger Bansemer
Graham Bernard
April 4, 2013 at 6:06 pmNone.
G
Cameras: Canon XF300 + PowerShot SX50HS Bridge -
Roger Read
April 4, 2013 at 9:04 pmThanks for your replies, Guys. I was afraid that would be the case.
However, having experimented a bit more, I have discovered that by offsetting the centre of rotation in the Pan/Crop window, and then rotating about the new centre, a reasonable approximation to the flight of the ball results. It’s a bit fiddly getting the initial and end positions correct, but far easier than plotting dozens of keyframes.
Hope this might help others with a similar problem in the future.
Paul Gregory
April 5, 2013 at 12:23 amI haven’t tried it but doesn’t the pan-crop tool have a setting that allows you to set the amount of smoothness that is used between key frames? It might me worth checking out.
Thanks in advance
Paul Beller
April 5, 2013 at 9:40 amit is the only thing that i really miss in vegas: moving an object on a curved path, like you can do in after effects. could you share your project, i mean your event with your pan/crop settings? i wish i could take a look at your experiments with it.
regards,
paul -
Roger Bansemer
April 5, 2013 at 10:54 amThat’s interesting about the “rotate from center” but that means that the video will tilt. You haven’t found a way to make it do that and still keep the video horizontal have you?
I have often wanted to pan around a shot without going in a straight line. I guess that will be the next upgrade for 150 bucks.Roger Bansemer
