Activity Forums Adobe After Effects moving all keyframes
  • moving all keyframes
    Posted by Josh Stanley on April 5, 2005 at 4:51 pm
    ok this is probably really simple, but I cant seem to figure it out. If I have animated the postion of a layer (for this example, lets say in a circle) but then later I decide i want it to move in that circle, but lower down on the compostion. Is there a way to drag the object and position it without creating a new keyframe, but adjusting all the keyframes in the animation to that new position? I have done this before, so I believe it is possible, I just dont know what I did the time it worked and now I cant seem to do it again. Any help would be appreciated.
    Josh
    Yoondo replied 21 years, 4 months ago 4 Members · 4 Replies
  • Dan Ebberts
    April 5, 2005 at 5:11 pm
    Precomp and move the new comp?
    Dan
  • Matt
    April 5, 2005 at 5:13 pm
    The way I do it is to select all your keyframes in the timeline. Then up in the comp window click and drag on one of the keyframe points (denoted by a dark X). This should move all of your keyframes. If there’s an easier or precise way of doing this I’d like to know.
  • Josh Stanley
    April 5, 2005 at 5:21 pm
    Dan and Matt
    Thanks alot, both those solutions solved my problem. Just what i was looking for. You guys rule.
    Josh
  • Yoondo
    April 6, 2005 at 1:58 am
    If you are still up for it, there is one more way to do this.
    Simply create a null object in the timeline then parent the layer(with keyframes)
    to the null and move the position properties of the null to desired. This way,
    you can still have the original layer in the comp and keep your keyframes of the
    layer at the original place.
