Moving all files to a different disc
Posted by Ben Edwards on August 17, 2009 at 10:39 pmI have Vegas Studio Platinum Pro Pack. I have just got a new USB2 drive. I tried copying a whole project folder onto it and the project opened OK from new drive but used the media from the original drive. Is there a way on moving everything onto a different drive?
Ben
Tyson Onaga replied 17 years ago 3 Members · 4 Replies -
Mike Kujbida
August 17, 2009 at 10:50 pmAfter you copy everything to the new drive, rename the original project folder something like MyVideo-old.
That way, when you open the project from the new drive, it should say something like “can’t find file *** – what should I do” and give you several options.
Point it to the folder on the new drive.
Once it’s told the new location, it should say something like “I also found file ** in this location. Should I use it?”
Say ‘yes to all” and it should load the rest of the files automatically.
If the new folder has several sub-folders, you may have to do this for each sub folder.
Once everything is loaded, save the project again and give it a new name so that you know it’s on the new drive and not the old one. -
Tyson Onaga
August 17, 2009 at 11:10 pmYou can do as Mike suggested and that will work fine. However, if you want to work with multiple disks and/or with multiple machines … and never have Vegas ask you where “such-and-such” media file is … then the command you want to integrate into your working model/environment is SUBST.
Best.
Mike Kujbida
August 17, 2009 at 11:29 pmSUBST?
That’s a new one one me.
Care to explain further please. -
Tyson Onaga
August 18, 2009 at 12:06 amFirst, I’m going to use forward slash “/” instead of backslash cause I can’t seem to get this forum editor to process backslashes correctly. Replace them mentally from here on …
Given: Work and third party material for Vegas on one or more HDs.
Desired: The ability to move material from HD to HD, machine to machine seemlessly (to Vegas and possibly other apps as well).— Scenario 1 —
Let’s say you work with a single machine. Your work is on D: and the directories are something like this:
D:/VegasProjects/OscarWorthy2009/ProjectX/…
D:/VegasProjects/OscarWorthy2009/ProjectY/…
D:/VegasProjects/OscarWorthy2009/ProjectZ/…where the subdirectories within Project X, Y, and Z may or may not be similar.
You use additional material which you like to keep separated as they may be third-party, reused, and not used solely by a single project. Let’s say the structure is something like this:
D:/ExternalCoolStuff/VendorA/…
D:/ExternalCoolStuff/VendorB/…
D:/ExternalCoolStuff/VendorC/…You would like to be able to move all or part of this to another HD (say F:) and Vegas will not be the wiser.
— Using SUBST —
SUBST(itute) drive is a old DOS-era command. Essentially (in programmer-speak) it is indirection.
Given Scenario 1, you will now do your work on W: (for Work) and external stuff will be on X:. Execute the following in a DOS command box:
SUBST W: D:/VegasProjects
SUBST X: D:/ExternalCoolStuffOpen Explorer and you should see two new drives W: and X:
The contents of W: should be:OscarWorthy2009/ProjectX/…
OscarWorthy2009/ProjectZ/…and X: should be:
VendorA/…
VendorB/…
VendorC/…— Working with SUBST —
Do all your work as before … EXCEPT … make sure you add files (drag-n-drop, etc.) from W: and X: … never D:. If you select an item in the Timeline, R-Click, Properties … the file path should be W:… or X:…
— Scenario 2, Moving Stuff Around —
You run down to Costco and get yourself a couple of the 1 TB drives. You would like to use one for work and one for external. The physical drives assigned by Windows are F: and G:
Re-SUBST ’em …
rem *** delete the SUBST drives
SUBST W: /d
SUBST X: /drem *** re-SUBST ’em
SUBST W: F:/VegasProjects
SUBST X: G:/ExternalCoolStuffLook at Explorer.
W: and X: should be identical as before … except W: is actually pointing to F:/VegasProjects and X: is pointing to G:/ExternalStuffOpen a Vegas project.
It should be seemless.Note, you cannot delete a SUBST drive while it is in use. Therefore, if you need to re-SUBST, close all apps using anything (e.g.) on W: and X:. Make sure Explorer and DOS command boxes are not pointing to W: or X: … then re-SUBST.
You should be able to copy a Vegas project and its media to another HD on another machine … and if W: and X: are properly set for that machine, Vegas should not know anything is different.
— Setting Your Environment —
Once you’ve settled on how many SUBST drives you’ll need for your work, create some batch file that do the SUBST-ing for you. You may want to have a collection of bat files that use a single bat file that has the [dr]:/VegasProjects and [dr]:/ExternalCoolStuff within. That way, you can move everything to a different PC, change the ONE bat file, and that machine is then configured properly to create W: and X:
I.e., you may have a bat that executes something like this:
SUBST %vegasWrkDr% /d
SUBST %vegasExtDr% /dSUBST %vegasWrkDr% %vegasWrkPath%
SUBST %vegasExtDr% %vegasExtPath%where the environment variable assignments (SET vegasWrkDr=…) are in a single place.
Once W: and X: are set, you should be good to go.
Best.
