Activity Forums Adobe Premiere Pro Moving a sequence from 2015.4 to 2015.2 doesn’t work
  • Moving a sequence from 2015.4 to 2015.2 doesn’t work
    Posted by Philip Owens on October 31, 2016 at 4:39 pm
    Project started in 2015.2, took it home to work on it on my 2015.4 version. Trying to move the sequences back into 2015.2 using FCP XML causes:
    1) A folder of media, all of which is already on the system, and
    2) Lots of clips missing in the timeline.
    Note that I removed all effects from the timeline before exporting the FCP XML, knowing that some things mightn’t transfer (Lumetri, most likely)
    I contacted Adobe support, who helpfully told me “there is no way to move a sequence back to an older version apart from the FCP XML method”, which seems absurd, especially between point releases.
    Jon Doughtie replied 9 years, 6 months ago 2 Members · 1 Reply
  • Jon Doughtie
    October 31, 2016 at 5:02 pm
    We have successfully moved sequences using the FCP XML workaround, but only between releases that are right “next door” to each other. i.e., 2015.4 to 2015.3.
    System:
    Dell Precision T7600 (x2)
    Win 7 64-bit
    32GB RAM
    Adobe CC 2015.02 (as of 6/2016)
    256GB SSD system drive
    4 internal media drives RAID 5
    Typically cutting short form from HD MP4 and P2 MXF.
