Activity Forums Maxon Cinema 4D Moving a camera’s position without altering key frame movement
  • Moving a camera’s position without altering key frame movement
    Posted by Jared Sales on October 22, 2016 at 2:52 pm
    I am new to Cinema 4D (R17), I am well versed in After Effects (10+ years). I tracked some handheld camera footage and when I put that camera in my scene, I need to adjust it to capture the objects. However when I change the position it doesn’t alter all the key frames and jumps back to the original position after a frame. I know in after effects if you high light all of the keyframes and move your object it updates them all to the new position. I tried doing this in cinema 4d but it didn’t work. I tried googling this as well so my apologies if there is an existing answer to this question.
    Jared Sales replied 9 years, 10 months ago 2 Members · 2 Replies
  • Adam Trachtenberg
    October 22, 2016 at 3:06 pm
    You need to be in animation mode when you move the camera (Tools>Modes>Animation). When you’re in animation mode you can move objects and their keyframes will come along for the ride.
    Another option would be to put the camera in a null and move the null instead of the camera.
  • Jared Sales
    October 22, 2016 at 3:21 pm
    Thank you for your response. I tried to do both but the camera still “jumps” back to its original position. I will continue to tinker with it as I am a newb.
