Activity › Forums › Adobe After Effects › Movies for Blackberry
Posted by Dasha Legge on May 13, 2009 at 1:58 pmHello,
I have recently finished a movie that I will eventually need to deliver as a movie for a blackberry. Has anyone got any advice on what format and size I should be using.. or any other tips?
Thanks, Dasha.
Dasha Legge replied 17 years, 4 months ago 2 Members · 5 Replies -
Roland R. kahlenberg
May 13, 2009 at 4:31 pmThe sizes and datarate should be pretty much fixed, especially the size. Have you performed an online search? Let us know what you find and also let us know of the server that you used. It’s nice to know, after being beyond the multimedia loop, how the video actually gets transmitted and by whom.
Cheers
RoRKbroadcastGEMs – AEPro Volume 02 (Professional Adobe After Effects Project Files – Now Available).
Adobe After Effects Training in South East Asia.
Dasha Legge
May 13, 2009 at 9:35 pmHello,
I have found out that blackberrys do vary slightly and have found this useful page that has the specifications for all the different types of blackberries.
Not sure I know what you mean by server… the movies are going to be actually on the blackberry…
Thanks!! I should really research before I post!
Dasha.
Dasha Legge
May 14, 2009 at 8:33 amOk, further problems, found out they are upgrading to bold.. which if you look at the link in the previous post uses 24 frames movies… My video is at 30 frames….
What should I do?
Thanks, Dasha.
May 15, 2009 at 2:44 pmAFAIK, 24fps should be the maximum DESIRED frame rate BUT you should be able to make do with a lower frame rate – something like 15-18fps to give a full-motion effect without the user noticing any dropped frames.
As for methods for going from 30 to 24, there are a couple of AE articles and tutorials in the COW library that you should look into.
HTH
Dasha Legge
May 15, 2009 at 2:50 pmCool thanks I shall have a look for those. Do you know what effect changing frame rate has on music? will it sound weird??
