Activity Forums Maxon Cinema 4D Movie with shadow
  • Movie with shadow
    Posted by Hans Meier on May 27, 2008 at 4:38 pm
    I guess that this has been asked a million times before, but I’m really stuck here.
    I have a simple animation of a cube, a light and a shadow on the floor.
    Now I want to render out the movie to use it in After Effects. I tried several things with After Effects Export and Multipass Rendering but somehow nothing really works out. What is the easiest way to achieve a rendered movie with transparent background BUT including the shadows on the floor (without showing the floor)?
    Sorry again! 🙂
    All the best
    Hans Meier replied 18 years, 3 months ago 3 Members · 5 Replies
  • Brian Jones
    May 27, 2008 at 10:18 pm
  • Randy Johnson
    May 28, 2008 at 5:49 am
    the link didnt work for me.
    So i have copied and pasted from the maxon FAQ: lighting section
    Problem
    How do you cast a shadow on an plane with only the shadow being visible, not the plane?
    Detailed Description
    How do you set up a scene so that you can render out a shadow of an object and composite a background image for the shadow to be cast on?
    Solution
    This is easily accomplished using the Compositing tag (R6/7: Render Tag). Add this tag to any shadow casting object(s) and disable the Seen by Camera option, while making sure Seen by Rays and Cast Shadows options are enabled.
    Add a compositing tag to the object containing the background image (a plane works best – background objects won’t work) and activate the Receive Shadows and Compositing Background options.
  • Hans Meier
    May 28, 2008 at 8:31 am
    Hi Brian and Randy,
    I’m aware of the compositing tag but it doesn’t seem to help me for what I’m trying to achieve.
    When I’m using the compositing tag, my render-file will have no floor. That’s correct – but there is also no shadow rendered.
    I tried using multipass-rendering and rendered the shadow only. That works, but then I have no transparency in the resulting pass-file.
  • Randy Johnson
    May 28, 2008 at 8:55 am
    Shadow passes dont have alpha they end up bright white..and the shadow. You need to multipy over your other layers.
    Also you use a compositing tag on both the object and the floor.
    /randy
  • Hans Meier
    May 28, 2008 at 9:43 am
    Randy,
    thank you so much! The multiply-tip was just what I needed.
    Thanks again…
