Activity Forums VEGAS Pro Movie Studio 6 Progressive PAL DVD. Is it possible?
  • Movie Studio 6 Progressive PAL DVD. Is it possible?
    Posted by Steven Durbidge on January 4, 2008 at 4:52 pm
    I would be very grateful if step by step instructions could be given for producing a progressive pal dvd using Movie Studio 6 and DVD Architect Studio 3.
    I have experimented with settings but whenever I render my pan and crop slide-shows an interlaced MPEG2 file is the result.
    My DVD player can output 720p and my TV can accept 720p but I can’t make a 720p disc!
    Edward Troxel replied 18 years, 8 months ago 2 Members · 5 Replies
  • Edward Troxel
    January 4, 2008 at 4:57 pm
    You may have to upgrade to the full version of Vegas. I know you can’t access the “Custom” settings in the Movie Studio versions which is where you would typically change that. If you don’t have a preset for it, you need to upgrade.
    Edward Troxel
    JETDV Scripts
  • Steven Durbidge
    January 5, 2008 at 4:22 pm
    Edward,
    Thanks for replying again to my posting.
    You’ve confirmed what I guessed. I couldn’t find any more settings to experiment with; but it’s strange having under ‘Project Properties’ a ‘Progressive’ setting under ‘Field Order’.
    Can you recommend an upgrade procedure?
  • Edward Troxel
    January 5, 2008 at 6:55 pm
    Render properties override Project properties.
    Edward Troxel
    JETDV Scripts
  • Steven Durbidge
    January 9, 2008 at 4:07 pm
    Edward,
    I understand. Thanks for your help. I’ve downloaded a trial of the Platinum Edition. I can now render as progressive (avi), now I have to research how DVDA will produce a progressive disc!
  • Edward Troxel
    January 9, 2008 at 6:55 pm
    Please note that the “Platinum” is still a “Movie Studio” version and not the FULL “Pro” version so there’s still limitations over the full version.
    Edward Troxel
    JETDV Scripts
