Activity Forums Adobe Premiere Pro Movie out of sync – Help!
  • Movie out of sync – Help!
    Posted by Matt Liddy on May 1, 2005 at 10:37 am
    I’ve imported a whole bunch of clips from video camera and put together a family documentary which is about 2 hours long, with audio from various sources. This is really my first video editing project. I’m using Adobe Premier Pro.
    Inside Premiere, the video looks fine when I play it, perfectly in sync. However, when I exported the project to a DVD the sound and vision goes out of sync, with the audio ahead of the vision.
    I did an export to DVD straight from Premiere, not going through any other programs.
    I’m using 25fps as it’s for a PAL output. I read something that made me wonder if I’d stuffed up the sample rate. I was using 48,000 for that and 16-bit. My only guess was that I had some audio I imported from CD using Sound Forge, which I did at 44,100. However, once I imported that into Premiere, I was under the impression that it conformed the audio to the correct sample rate.
    Any ideas what the problem would be? Could it just be that Premiere is messing up the DVD burning process?
    Thanks for any advice you can offer!
    Matt Liddy replied 21 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
