Activity Forums Apple Final Cut Pro Legacy Movie length FCP
  • Movie length FCP
    Posted by Richard Chenoweth on October 25, 2010 at 6:30 pm
    I’m trying to make a :27 minute movie using FCP 6.
    Hardware is MacPro Dual Quad Core with 12 GB RAM.
    At 9 minutes, FCP suddenly got VERY sluggish and started crashing.
    Is it maxed out? The clips add up to about 2.5 GB of stuff… audio
    files, video, stills. No transitions added yet.
    Should I try to render down three or four segments as .mov and
    then put those together?
    Richard Chenoweth replied 15 years, 11 months ago 3 Members · 11 Replies
  • 11 Replies
  • David Roth weiss
    October 25, 2010 at 6:40 pm
    27-Mins. is nothing to sweat for FCP. 90-min. projects are actually doable. You evidently have some other issue(s).
    What type of material are you editing and on what hard drive subsystem?
    David Roth Weiss
    Director/Editor/Colorist
    David Weiss Productions, Inc.
    Los Angeles
    http://www.drwfilms.com
    A forum host of Creative COW’s Business & Marketing and Apple Final Cut Pro forums. Formerly host of the Apple Final Cut Basics, Indie Film & Documentary, and Film History & Appreciations forums.
  • Richard Chenoweth
    October 25, 2010 at 7:03 pm
    Thank you Dave and David for responding.
    The footage I’m using is archival old film footage. Project is set up at 720×540.
    The archival b/w footage is all 4:3. Some of it was .flv I converted to .mov and
    some of the archival was .mpeg 2 which I demuxed into .m2v and .aiff.
    It all seemed fine until I got to a piece I got from from YouTube at about 9 minute
    mark, then it suddenly got really slow.
    Thank you for your help!
    Richard
  • David Roth weiss
    October 25, 2010 at 7:05 pm
    [Richard Chenoweth] “some of the archival was .mpeg 2 which I demuxed into .m2v and .aiff.”
    That’s your problem. The .m2v needs to be something like dvcpro50.
    David Roth Weiss
    Los Angeles
  • Richard Chenoweth
    October 25, 2010 at 7:07 pm
    Thanks Dave and David,
    I forgot to say, the “scratch disk” is a Hard Drive #3 in MacPro. The files and resources are
    on Hard Drive #2 MacPro.
    Would it help if scratch and files were all on same disk?
    Richard
  • David Roth weiss
    October 25, 2010 at 7:24 pm
    [Dave LaRonde] ” David mentions DVCPro 50, and that’s okay. You can also use FCP’s go-to codec, ProRes 422.”
    DVCPro50 simply offers the smallest file size of any 4:2:2 codec. By the time video is squeezed at 25 to 1 compression just about any codec will do, but I will always choose one in 4:2:2 color space in case there are graphics and/or text elements.
    ProRes really could be considered overkill, but I too use it much of the time because of it’s high-performance and because hard drive space is virtually meaningless to me.
    David Roth Weiss
    Los Angeles
  • Richard Chenoweth
    October 25, 2010 at 7:46 pm
    Hi Dave and David,
    I used 720×540 because all this old footage was 4:3. And still be able to burn it into DVD format,
    so maintained 720 in the horizontal.
    Should I have stuck with 640×480? If I used 720×480 I’d have some black bar letterboxing.
  • Richard Chenoweth
    October 25, 2010 at 8:11 pm
    Thanks again Dave and David,
    I have changed the original archival MPEG-2 directly into DVCPRO50 using Streamclip.
    This creates a MUCH higher quality clip than the .M2V but is 8 GB to the M2V file size of 1 GB.
    I can bring this into FCP or were you referring to changing my Sequence Settings to “DVCPRO50”
    as the compressor of choice?
    Many thanks, guys. I really appreciate the tips…
    Richard
  • David Roth weiss
    October 25, 2010 at 8:17 pm
    Since we have no idea what your seq. settings are now, it’s difficult to tell you. Probably yes however.
    And, there is a reason the DVCPro50 file is larger, it carries lots more information. Plus, it’s a realtime editing codec recognized by FCP, so loads less rendering.
    David Roth Weiss
    Los Angeles
  • Richard Chenoweth
    October 25, 2010 at 8:59 pm
    I was set on regular DV/DVCPRO-NTSC but have now switched it to the DVCPRO50-NTSC in Sequence Settings…
    Thank you gents very much!
    Richard
  • Randy Lee
    October 25, 2010 at 9:24 pm
    Check your aspect ratio – you’ve got quite a few to choose from in Final Cut, but less that will play nice with your footage. If you don’t know what you’re doing there, it’s often easiest and best to go with the “default” ratios. If you think you’ve got a handle on what you’re doing, then the only thing I would advise is that you convert as much as possible to the same framesize, codec, and aspect ratio before editing so you’re not constantly rendering.
    Good luck, and let us know how things are coming along, or if you run into more issues.
