Activity Forums Apple Final Cut Pro Legacy Movie compressing in 4:3 instead of 16:9 in FCP 6
  • Movie compressing in 4:3 instead of 16:9 in FCP 6
    Posted by Alexandra Hidalgo on December 19, 2012 at 3:33 am
    I shot footage with my Cannon HV-30. The sequence settings are Frame Size 1440×1080, aspect ratio HD(1440×1080)(16:9) and pixel aspect ratio HD(1440×1080). The QuickTime Video settings for compressor are HDV1080i60. However, when I compress it into H.264 using 100% of the original, I end up with a 4:3 movie, except for the YouTube version (https://youtu.be/VXAzs9caaZY) which for some very confusing reason is in 16:9. Do you guys have any advice on how to fix this?
    Thank you, thank you as always!
    Alex
    Oxana Holtmann replied 13 years, 9 months ago 3 Members · 7 Replies
  • 7 Replies
  • Rafael Amador
    December 19, 2012 at 12:19 pm
    Hi Alexandra.
    QT do not understand other than Square pixels.
    Export your movie with 1920×1080 Square Pixels.
    rafael
    http://www.nagavideo.com
  • Alexandra Hidalgo
    December 19, 2012 at 3:31 pm
    Thanks, Rafael. Do I leave everything else as is and only change the pixel rate in the inspector?
  • Rafael Amador
    December 19, 2012 at 4:38 pm
    [Alexandra Hidalgo] ” Do I leave everything else as is and only change the pixel rate in the inspector?”
    You need to change the dimension as well.
    1440×1080 HD pixels is the equivalent to 1920×1080 Squared pixels.
    That will shows up everywhere as proper 16×9.
    In Compressor, set “Frame Control ON”, and “Resize Filter: BEST”.
    It will take longer, but you will achieve better picture quality.
    rafael
  • Alexandra Hidalgo
    December 19, 2012 at 7:10 pm
    I was just wondering what those dimensions should be. I’m now running it with display bounds 1920×1080 as Rafael recommended. I’ll report on how it goes…
  • Rafael Amador
    December 20, 2012 at 6:00 pm
    HDTV has just two standard sizes:
    – 1920 x1080 SQ Pixels
    – 1280 x 720 SQ Pixels
    Other sizes and pixels aspects (1440×1080, 1280×1080, 960×720,..) are acquisition formats (HDV, DVCProHD,..).
    rafael
  • Alexandra Hidalgo
    December 20, 2012 at 9:28 pm
    It took a long time to process but it is beautiful!!! Thank you, thank you, Rafael. That was so helpful and now I have much better image quality than I did before!
  • Oxana Holtmann
    December 20, 2012 at 10:52 pm
    Hi Alexandra,
    I have exactly the same question and I didn’t understand exactly what Rafael recommended. I have FCP 6 and my footage and sequence is 1440×1080 (Canon XA10) Normally I do Export- QT Mov – Current settings. What should I set Current settings for. And when I bring it to Compressor how do I compress it to be good for youtube.
    Thank you!
    Oxana
