Activity › Forums › Adobe After Effects › Move/rotate/Scale Parent without hierachy.
  • Move/rotate/Scale Parent without hierachy.
    Posted by Multipasser on March 18, 2013 at 5:50 pm
    Hey Cow’s
    I have been searching for a solution but I cannot seem to find it, or I’m using the wrong searchwords.
    Lets say you have a null setup in the left corner and 20 layers are parented to that null.
    Now I want to rotate/scale all the layers with the null in the right button side.
    What I do now is unparent the 20layers, move the null and parent them back.
    It is ‘ok’ when I only have 20 layers in the comp, but not when I have 500 and I need to select only 20 🙂
    Is there a solution? Some kind of dynamic parenting trick?
    Roland R. kahlenberg replied 13 years, 6 months ago 2 Members · 1 Reply
  • Roland R. kahlenberg
    March 18, 2013 at 6:30 pm
    [Jos Vermeulen] “Lets say you have a null setup in the left corner and 20 layers are parented to that null.
    Now I want to rotate/scale all the layers with the null in the right button side.”
    Create a Null and place it where you want the center of the scale to be. Then parent the original Null to this new Null. Then scale this new Null.
    HTH
    RoRK
    Intensive mocha & AE Training in Singapore and Other Dangerous Locations
    Imagineer Systems (mocha) Certified Instructor
    & Adobe After Effects ACE/ACI (version 7)
