Activity › Forums › DaVinci Resolve › Movement with Keying in 15b Mac
Posted by Ted Irving on August 2, 2019 at 4:09 pmThe background moves with the person, or object, that is keying over the background. How can we get this set to not move the background but just the person/object being keyed?
Ted Irving
ENG Cinematographer
http://www.beingus.tv
tedirving@beingus.tv
@_beingUS_TVGlenn Sakatch replied 7 years, 1 month ago 3 Members · 5 Replies -
Marc Wielage
August 4, 2019 at 7:32 amI don’t understand what you’re saying. Is this a green screen background? Are you keying the person itself? Are you keying only what’s around the person? Are you using a garbage matte? Is something being tracked?
Explain this with a lot more words, and maybe upload a still frame, and I think you’ll get more feedback.
Ted Irving
August 4, 2019 at 1:44 pmJust a simple keying of a person over a still background. When trying to move the person from left screen to right everything moves, the background moves as well as if is merged with the top layer person on a green screen.
Ted Irving
ENG Cinematographer
@_beingUS_TV -
Glenn Sakatch
August 10, 2019 at 7:56 pmPerhaps a screen shot of the layout, and where you are doing the movement?
Glenn
Ted Irving
August 14, 2019 at 1:58 pmHere is a link to what is happening. You can see the alpha being cut as you move the keyed subject around.
https://www.dropbox.com/s/olwl53nd0ldibnf/IMG_2411.MOV?dl=0Ted Irving
ENG Cinematographer
@_beingUS_TV -
Glenn Sakatch
August 15, 2019 at 1:30 amOk, just to clarify, the background isn’t really moving with the person. The background is totally static, what is happening is your key is cropping out the background. As you expand your key frame, you are expanding the amount of background that is visible. I think we all thought from your initial post, that if you panned the subjects left, the background was moving left as well.
Try putting a window/mask around the green subjects, to change the area Resolve is working on.
I’m guessing your two images are not the same size, and your green screen is the smaller of the two?Part of the problem is probably that you are pulling a key in Resolve, which wouldn’t be my first choice. I would probably prefer to take it into fusion, which is more designed for comp work.
Glenn
